Won't Start, Smoke from under dash
McDude
Minneapolis, MN
1986 CJ7, AMC 258, T176, DANA 300, AMC 30/Dana30
1986 CJ7, 350, TH350, DANA 300, AMC 30/Dana30
Hello everyone,
Pretty new to the forum
I have a 1986 CJ7
All of the wiring is a complete mess
But this morning when I drove to work the car started up fine, suprisingly for the cold weather. But when we came back from lunch the jeep wouldn't start.
I could hear the starter spin but nothing would happen.
After about a second some white smoke started coming in from under the dash.
So I got out, and tried jumping the solenoid with a pair of pliers.
This time it would only sometimes spin but others not turn over.
I ended up pushing it across the parking lot and popping the clutch to get it home. With the ignition on, I could hear my ground on my battery "Sizzle"
I tried jumping it across the solenoid again but nothing happened.
When I got it home and tried to start it again, I could hear the starter "Clunk" once, and nothing would happen and I would lose all power. I would have to turn the ignition all the way off and back on to get power again. The jeep behaved similar to this a few months ago when I wasn't making a solid positive battery connection.
AMC 258 i6 / 4.2l , Tremec T-176
THANKS!
Ouch, start with clean battery terminals, clean grounds, drop battery off to have it tested at parts store, white smoke from the dash is not a good thing. You might wanna inspect your wiring to ignition switch and fuse panel check for burnt wiring. Let us know how it goes
STOP driving it and disconnect the battery POS(+)till you find the source of the smoke.
You have a serious car fire potential here. :eek:
Good luck,
^^^ This
Update:
The last owner had some Bolt Down connections to the battery terminal (basic hoop but a bracket that pinches the cable down) I noticed the bracket wasn't flipped upside down and making a solid connection, so i flipped it and it starts perfectly fine.
What was the source of the smoke? :confused:
;) smoking oil = FIRE! Glad everything worked out without .... FIRE!
Burning Jeeps are not fun. Personal experience here. I got the underhood fire out on mine, but not before there was massive damage. I ended up having to replace everything under the hood but the long block and radiator.
