Suspension Yj spring swap on only the front?
Cj8guy
Washington
Jeep cj 8
Hi All,
I have a 1981 CJ8 and am in the process of restoring it, while I have the body off I am thinking about doing some suspension work, my front springs seem to be a bit flattened so I was thinking about replacing them. I see a lot of people recommend a Yj spring swap and I'm interested but I have a few Questions. Could I replace only the front springs with Yj springs? The back springs are the same so does replacing them make a difference? Also if it does make a difference how much do the back springs actually affect the ride and handling? lastly, how much does a Yj spring change the height? I can put in shackles to compensate but it would be helpful to know.
Thanks.
:welcome:
YJ springs are very different when it comes to compression, rebound, torsion and other things. Plus they really require different shocks.
I would not do 1/2 a swap as it would really affect handling. BUT, since you're in an 8 you may not notice it as much.
IMHO, while you have everything apart and have to do the front I would do a complete YJ upgrade. The difference is astronomical and your back / butt / off-road capabilities will thank you... :chug:
I'm going to jump in on this thread- is there a difference in ride height with the YJ springs on a CJ5 ? I understand the length of spring changes but what about the height? Trying to decide on stock YJ springs or 2" lift springs.
I need new springs for my resto - might as well do the upgrade while everything is torn apart.
$190.00
  95.0%
