Build Thread 1 Ton 1980 CJ7
One1TonCJ7
Hamilton OHIO
1980 CJ7 - GM 1ton Axles, 38in Swampers for offroad, 36in Millitary M/T's for Street, 5pt harness, 350 v8 w/ Muncie 4speed trans, NP205 T-case. 4in suspension lift, SOA. w/ 3 in body lift
1993 Chevy Blazer K1500 - 8 In suspension lift, 3inch body lift, 350V8 w/ 563HP, 612ft/lbs tq. 38 Mickey Thompson's, 5.13 gears, and 10mpg!!!
Dang! that should be a FUN beast!
Thanks fella's! i need to build my drive shafts and put in new brake lines and then take off that hideous body lift and it'll be ready to roll! hopefully not literally lol. and those LED's are stupid bright!
That bumper is custom made and a one of kind. Sweet lookin' ride, looks a little too clean though. Take some dirty jeep porn pictures.
hahaha, it will have some dirty porn pictures the day its all done. Thanks!
haha i know what thats like, went from swapping stock axles to dana 70, whats the widthh on yours?
with my 38in Swampers i wanna say its 85in outter wheel to outer wheel... Car Trailer is 83 inner fender to inner fender lol... time for some more fab work!
Those headlights look pretty cool! Do you have any more pics of them with them on? How much?
Nice job with the Jeep. It looks badass! :chug:
did you go with the full width kit or use cj springs and rewelded the springpads
On the rear springs i moved the spring pads in about 3 inchs, on the front i was unable to do that because the Passanger side spring perch is actually apart of the pumpkin. so i outboarded the front springs about 2in from factory mounts. i also moved the front axle forward 4 inchs, since i was needing a new driveshaft anyways, i used 1/4in 3x3 angle with 1/4 gussets, and all grade 8 bolts and welded the mounts to the frame. Ill try and get some pictures up asap. Ruffstuff Specilties has an outboarding kit that i should have bought cause it seems like it would have ALOT less headache!!
$100.00
  50.0%
