1965 CJ5A - I can't get the Transfercase to stop leaking into Emergency Brake!
Jcasey1966
Avondale, PA
1965 CJ5, MarkIV, Tuxedo Park, F Head Four Cylinder, Column Shift, Model 18 Transfer Case, T90C Tranmission
I replaced all gaskets, cleaned and lightly greased the metal spacers, between spedo gear box and Transfer Case , replaced and installed with RTV transfer case gasket, Pulled Oil Seal and reinstalled new oil seal and seal ring gasket and installed with correct tool to not scratch or bend ring. installed gasket for brake backing plate and felt oil / dust seal. All via specs in Manual. Still leaking
    Best for votes
    on specific items
