1966 Jeep Gladiator
1966 Jeep Gladiator
GoldenEagle36
SW Pennsylvania
1977 cj7 Golden Eagle 304,automatic, Quadra-trac, full restoration just "finished." 4 inch superlift, lift shackles in the front, sitting on some KM2 Mud terrians
1999 tj 4 cylinder ax5 trans 3 inches lift 31s
1956 Dj3a all original except axles and engine, Hurricane 4 cyl. 4x4 conversion, 27,500 original miles 58 Jeep-A-Trench cj5 8000 miles.
i am looking to buy a 1966 jeep gladiator that is in decent shape and i was wondering if anybody knew anything about these and i have some questions.
is the Dauntless Buick 225 V6 350 v8 a good engine?
it has a ramsey PTO winch with a huge bumper on the front is that a special order from factory?
and the last is it was a camper special but should there be toolbox compartments in the side f the bed??
any info will help me thanks :chug:
The Buick Dauntless Buick 225 V6 engine was a 225 c.i. or 231 c.i. V-6. If it has a 350 c.i. its most likely a Chevy conversion. The Dauntless Buick 225 V6 or the Chevy is a good engine.
I couldnt really find anything on the winch option. Pics would help.
Being more of a Cj based site Id point you towards asking this question over here : Jeep CJ-8 Scrambler Forums - Powered by vBulletin
There are alot of helpful guys there and a few of them will point you to the best sources for the Full size Jeep trucks. Gladiators are cool. :D
Hope this helps and you can pm me with other questions if you please.
Pete
is the dauntless 350 v8 a good engine?
well the air cleaner cover was good and i dusted it off and it said Dauntless Buick 225 V6 350 and also on the fender it has 350 v8 and its factory
also i looked up that it was used from only 69-70 then discontinued but that was all i found
Thank you Petescj for the help
To help decide if you should buy it we need to know the price and what kind of shape it's in. Can you post pictures? How much is it?
In the mean time I'm learning a little about the Dauntless Buick 225 V6 engine. It sounds like the Dauntless Buick 225 V6 V6 is a Dauntless Buick 225 V6 V8 with 2 missing cylinders. Sounds like parts are very interchangeable.
Engines « Earlycj5.com
Dauntless V6
The Jeep “Dauntless V6″ is a 90 degree V6 designed by Buick in the early 1960s. All internal parts are interchangeable with the more familiar Buick 350, also called the “Dauntless V8″ by Jeep in the Gladiators and Wagoneers. The only parts that are not interchangeable are the crankshaft, camshaft, and valves. Kaiser purchased the right to the Buick V6 to use in Jeeps in 1965, in 1966 they started appearing in CJ-5s, 6s and Commandos as 1967 models.
See this page for more detailed V6 information The Dauntless V6 Page. Complete engine specs, casting numbers and FAQ’s are available on this page.
Well the guy wants 600 but it has sat in a barn for 18 years up here in pa but before that the truck was from Colorado but the interior is immauclant but I tried to get it running but the bendix wouldn't work on the starter so it was a no go. All in all it's in decent shape it was a camper special I thought 600 was a great deal. The motor turned good by hand and the oil was a good color.
