Build Thread 1973 CJ5. From rot to trail/hunting rig
Lookin good............keep it up hunting season is a few months away.
Kyle,
Keep up the good work............your getting closer...........Did you keep your old Harness?
That's a good way to start by replicating what you already have circuit by circuit.
Yes I have the old one
:)Lay it out on the ground alongside the Jeep so that you can get a feel for where everything goes...........12 volts is pretty simple one positive + and one ground -
some circuits will assume a ground through the frame or chassis but if I was you I would run dedicated grounds on each circuit especially lights. Once at the end of the circuit like your tail lights you can daisy chain the ground from side to side.
Also the ground wire should be of equal size to the hot lead..............On headlights some guys like to trigger a solenoid near the lights so that full power is not traveling down your 16 or 14 gu wire from your switch............plenty of good articles on the internet. Don't be afraid to split off a separate circuit for later upgrades.......once you get the feel for understanding you'll catch on. Call me if you have any questions.
:D:D:D:D
Take your time on the routing of the wiring too. Make sure you know where everything is going before you start cutting wire. I made sure it was also secure in place before I cut it to length so nothing was too tight.
:)Troy,
Lookin good..............keep it up the finish line is in sight!
:D:D:D:D
Who is Troy? lol
:)Kyle.............sorry about that..........to many builds going on and my fingers don't always type what I'm thinking.......(LOL)
:D:D:D:D
