Members CJs 1973 CJ5, New member, Socal, ready for dirt
leichardti
Lake Arrowhead
73 CJ5, 258
I'd replace that plastic valve cover otherwise nice starting point
Most of the ones im am finding are for 4.2, 1981 and up. Do you know if those will fit the 73? Thank you for your time
Depending on the edition of your 73 it may bolt right up. Most need small modifications.
Link --> (Darn Google AI keeps rewriting my Google links... Grr)
A 1981 AMC 258 i6 / 4.2l valve cover will generally bolt onto a 1973 258 engine, but it is not a direct, trouble-free swap. While the bolt patterns are similar, the 1981+ engines transitioned to plastic covers and different gasket types (often a rubber molded gasket), which may not seal properly on the older 1973 head.
Key Considerations for the Swap:
  • Gasket Mismatch: The 1973 head uses a cork/composite gasket, while 1981+ typically uses a rubber gasket designed for a specific groove in the later cover.
  • Bolt Differences: The 1981 plastic covers may require different bolt lengths or flange studs compared to the earlier metal covers.
  • Best Solution: If switching from a '73 to an '81 cover, ensure you use the corresponding 1981-style gasket. Many enthusiasts prefer replacing both with aftermarket aluminum covers to avoid sealing issues, according to IH Parts America.
In summary, it will bolt on, but you may face significant oil leaks if the 1981 gasket and hardware are not used correctly on the 1973 engine.
Here is a thread discussing this issue.
Good Morning
I'm sure you are going to be replacing the Front Steering Components, and
Might have Missed it while Speed Reading though the previous posts.....
But Ray Charles can see that Cross Link with the Welded piece of Angle iron......
Otherwise it looks like a Great Find.
  5.0%
