1976-1995 Seat Risers/Brackets
Rescue Diver
Full Time Jeeper
Kansas City
1979 CJ-7 with a fiberglass body and 1982 wide track axles, 258 I-6 with a 1995 4.0 head, HEI distributor, Motorcraft 2100 Carb, T-18 wide ratio tranny, Super Lift Springs and 33s, a 1997 BMW 328i, and a 2010 REDLINE CONQUEST TEAM Cyclocross Bike. :)
I drilled the holes in the fiberglass tub floor to install the seats that came with my Pile O' Parts project and discovered that the passenger seat sits about 1" higher than the driver side. The seats are out of an 85 Mustang. The previous owner used the mustang sliders on both the driver and passenger seats, and bolted them to the Jeep risers with angle iron brackets. I seem to recall from my old jeep back in the 90's that the passenger seat didn't have a slider and that the bracket or riser was a little taller because of this. Is this right, or am I suffering from a fuzzy memory??? Either way, I'll most likely be removing the passenger slider and bolting the seat directly to the riser bracket to lower it to the same hight as the driver side that I plan to retain the slider on.
You are correct that the passenger seat does not come with slider normally. I still find that the passenger seat does ride higher in mine as well even though it does not have a slider. I swapped the stock seats for newer TJ seats though. Here is a photo showing the difference.
If you put a straight edge across the top what is the difference in height?:cool:
I removed the slider from the passenger seat and the height is pretty much perfect now. :)
