1977 CJ5 Transfer Case?
Howdy, my 77 CJ5 's both have Dana Spicer model 20 transfer cases, my 79 did also. I think from the late 60s thru 1979 these were used, not sure if others were as well during that time.
Not sure what you mean by shift pattern, straight line shifter, 4 positions, all the way back is 4 low, going forward is Neutral, 2 High and all the way forward is 4 High
Al
All three of mine came mated to a T-150 3 speed Transmission . That shift pattern was Left up-reverse, left down 1st, right up-2nd, right down-3rd.
Al
thanks now I get it. 4h,2l,N,4L. ok. I guess Im having issues with the 4L. then its ether not kicking in of its poping out.
thanks again great help.
on mine all the way up is 4x4
I just dont know if its Low or High.
thanks again.
It should be real easy to tell if its low or high if its in high it will drive the same as 2WD. If its in low you will only be able to go like 5mph in first. just don't do it on dry pavement.
