1979 CJ Brakes
grunt
My calipers are held by 2 bolts. The brake line and banjo fitting are in the way of removing that top second bolt to remove the caliper. To change the pads I had to remove the brake line, replace the pads and then bleed the system. Is there another way to do this? Seems ridiculous to remove the caliper you have to remove a brake line. Is there some trick to this?....Here is a pic....
