Build Thread 1983 CJ7 ReFurb.
Another minor update:
Have just been driving this bucket around town to see how long the dodgy engine and junky wore out T-5 Transmission would last. To my surprise, it has been running better and better, the smoking has all but stopped, still running 1 qt ATF in the crankcase. I have driven it about 1500 miles since the last update and I have become kind of fond of this rusty leaky junkpile.
Here is my plan which I hope to start executing in the next few weeks.
I have a clean fairly low mile 3.8 I6 from a postal jeep that I am planning to swap in for the AMC 258 i6 / 4.2l . The AMC 258 i6 / 4.2l is running pretty good right now but it does have a weird vibration now and then and given its history, it could explode at any moment.
Junkyard gm TBI with timing control.
T19 with 5.11 first gear from diesel F350. Already had this along with Dana 300 output conversion kit.
Rear axle - Weld tubes, 1 pc axles, 4.11 gears, selectable locker (OX)
Front axle - 4.11 gears, selectable locker(OX) if funds allow
YJ springs front and rear, 2.5-3" lift, 1/2" (0.5") body lift, 1" longer shackles front and rear, extend bumpstops
Tires - agonizing over this, I want 33-10.50 BFG's, but this lift combo may be marginal for 33's and i do not want to trim fenders. Hoping i can keep tires out of sheet metal with bumpstops, but if not, then i will go with 31x10.50's i suppose.
Electric onboard air mainly to run locker(s).
A handful of other little maintenance items and what not.
I am going to try and get all this done before the CO trip, because I would like to take a different rig this year for some knucklehead reason.
Anyways, I will update the build thread as the things occur. Probably.
sure does sound like a lot of fun i will be very interested in seeing progress
Ford T19 getting ready for mainshaft swap
T19 innards
Old Ford output shaft vs D300 output
T19 done
I like the stand you made! Simple and quite effective!
Hope you paint it! Cast iron engine paint looks great on transmissions! I use it on steering components as well.
Thanks for the details Pistol Dave. :notworthy:
PLZ keep us updated.
