Build Thread 1986 CJ7 Build
Here we show them our license and insurance info and vehicle mileage and pay $10 for a year or $20 for 2 years and that’s it. Out the door with a new sticker
Yup. Really sucks here along the Front Range of CO.
Most other areas of the state are dark RED though.
I hear that term. The Front Range. Is that the west side of the Continental Divide ?
After the long drive yesterday (70 miles), I took the opportunity to inspect for any leaks or adjustments needed.
I did find a "wet" area around the rear of the throttle body. Funny that it's there, because I haven't touched my fuel system lately. Took the air filter off and saw a puddle of oil inside. Sh$t !!
It appears I'm getting a bunch of blow-by and it's getting sucked into the air filter through the hose from the rear of the valve cover. I have a 10" round Edelbrock air filter, old school type.
There was probably 2 Tablespoons of oil in there and although the air filter assembly is fairly air-tight, it isn't oil-tight and it was seeping out and down the back of the throttle body.
Last time I changed the air filter was exactly a year ago and I didn't see this then. My guess is that this original motor is getting a bit tired and the rings are shot. I'll replace the PCV valve though, but I don't think it's the culprit.
Sounds like where my brother lives in Oregon. Up and down the North/
South I5 there.
Just spent an hour or so reading through this from start to finish. What an ordeal, but such awesome work! Thanks for sharing. I especially liked your results from clocking your Dana 300 . I have a Novak kit in the T18a in my Scrambler, but I bought it close to 20 years ago, before clocking was a 'thing'. Not sure if there's material on their adapter to drill it. I'm also going with Scout II D44s under it, I like how you did the narrowing on yours so you didn't have to outboard the springs. Nice job all around. :chug:
N9VIW,
Appreciate the kind words.
The build threads are a cool place for people to tell a story with lots of great info for others.
Great write up! Just finished reading the whole thing as I recently purchased my new to me CJ7 . I also have the HEI distributor and wondered how you got the stock tachometer working with it. What did you have to do? Mine does not seem to be working anymore.
Found my order from August of 2022...
Items Purchased on This Order:
Item Status*
Price
Qty.
Total
SUM-890148
Wiring Pigtail, HEI Power With Tach, Each
(Mfr. #: SUM-890148)
Ready to Ship
Ground
$9.99
$9.99
SUM-850047
Distributor, HEI, Magnetic Pickup, Mechanical, Vacuum Advance, Black Cap, Jeep, 232, 4.0L, 258, Each
(Mfr. #: SUM-850047)
Ready to Ship
Ground
$179.99
$179.99
TAY-84249
Spark Plug Wires, ThunderVolt, Spiro-Wound, 8.2mm, Red, 135/180 Boots, Jeep, 4.0L, L6, Set
(Mfr. #: 84249)
1 TAY-84249 is expected to ship on 08/15/22.
Backordered
Ground
$47.99
1 *
$47.99
Great write up! Just finished reading the whole thing as I recently purchased my new to me CJ7. I also have the HEI distributor and wondered how you got the stock tachometer working with it. What did you have to do? Mine does not seem to be working anymore.
Scotty,
I installed a 4.0 in my wife's CJ7 Laredo last year, and wondered how to get the tech to work. According to a note I made following a thread over at Pirate4x4 (I think), if you cut the solid grey wire that goes from the ECU to the coil and wire the ECU side to the red tachometer wire and the red/white tachometer wire to the other side of the grey wire, the factory tach will work. I haven't done it myself yet (lazy boy) but that's how they had it. A Goog for "five wires to fire" should bring you to the thread that mentioned it, or just Goog "factory CJ tach 4.0".
Looks like a great time !
That hail hurts. What seal was used around the glass ?
