Build Thread 1986 CJ7 Build
May 16, 23:
-Sent off my original/failing TBI injectors to Fuel Injector Connection in Georgia to be "refurbished". Fairly cheap at about $30ea, especially appealing since I'm just using them for spares.
-Along those same lines, I've recently collected other do-dads for spares as well. Such as...
TPS (Throttle Position Sensor)
MAP (Manifold Absolute Pressure Sensor)
Fuel Pump
Fuel Filter
Fuel Pump Relay
-Ordered a weld-in front cage kit from D&C Extreme down in Colorado Springs. They set up my R&Ps for me this winter and are a great crew. Was planning on dry-fitting the assembly, tack-welding the joints, then removing the whole cage to weld on the ground, away from the Jeep.
Anyone have a line on some of these floor plugs?
Need a few more of these metal ones because the plastic ones won't fit now with the Rhino lined floor.
There are several that I have used from different vendors. Even Home Depot. Just depends on the size. They make them for sink faucet holes also.
Thanks CJ. I did see some of those, but the only ones I've seen were chrome. Eee gawd, no chrome! :giggle:
I might have found some at Jeg's, but pricey little guys.
Yea, the stainless ones are out there but pricey and difficult to find.
Nope CJ. Pretty damn cold here now and I’m wishing for that South Florida sugar sand. I like that Ft Lauderdale stuff.
Don’t have the heat setup yet in the garage and it’s rough.
  • Wow
$20.00
  10.0%
