Build Thread 1986 CJ7 Build
Armyvet,
The Wagoneer Dana 44 front is about 4" wider than the widetrack Dana 30 in there now. As you mentioned, since the passenger spring mount is fixed on the housing, if you shorten the long side (driver) about 4", and slide in the spring mount the appropriate amount, it will "center" the housing under the Jeep. The passenger side dimension from spring mount to wheel mounting surface is about the same on both axles.
It's fairly common, if you don't go with the spring out-boarding route.
I'll have to get one shorter inner axle shaft. I'll be using the Dana 30 knuckles and everything on them, since everything is new from last winter. I'll need new outer axle shafts too to make this work, since the Wagoneer's are 19-spline and my current hub setup is 27-spline, iirc.
Sounds like a lot of $$$$ total lol. but since you already had some new components and to keep the same profile, especially from front to back makes sense, i assume the spring out-boarding route would be more economical for most trail rigs
Just like your signature says... Right? Ha!
3 new axle shafts will be about $450. I think if you actually bought an out-boarding "kit" it would be approaching that.
Who am I kidding though. We always end up spending more dough (and time) on these damn things than we planned.
I bet that pretty sand was cold on the feet this morning.
That’s interesting. Keep updating.
That saw is a marvel, got me one recently.
I would think your other inner C will dictate your caster. Do you know how much you will end up with…
Similar to what you are doing, I made my rear axle. One of those mods that are very rewarding.
Yes, correct. I ground down the other spring perch a bit in hopes of gaining another degree or so of caster. I simply measured with angle finder as I ground a wedge in the spring pad casting. Then, welded the relocated spring perch to match parallel. I do not know what I’m gonna end up with though for caster.
I am afraid you missed out on taking your axle build to the next level. I would have removed both C’s and still attain the same width. Also, know that in the unlikely chance that you wanted an LS swap, anything more than the final positioning of the pinion yoke in relation to the passenger side wheel mounting flange that the original Dana 30 provides, will have serious issues with the oil pan. As it is with the 30, you are Limited to the original small diameter driveshaft axle tube. FYI
KRUPP, I am going to have to state the issue with LS more accurately. If that larger 44 pumpkin brings the pinion yoke any closer than the 30 does to the oil pan, then it’s time to scratch heads. The good news is that lift springs will help, and you might not have to worry with anything non LS. Move on brother.
Patrick,
Thanks for the comments and I understand what you're saying. I was kinda stuck with cutting down the long/driver side, since I'm not out-boarding the springs and want to center the axle beneath the vehicle. The Wagoneers are supposed to have more caster than the Scouts, which is why I used one over an IH. We'll see though. Years ago I had a '79 CJ5 with a Scout front end swap and it had zero caster - want to avoid that again.
Zero chance for an LS motor swap on this one.
You might be able to drive the seal further. Only you can tell.
$20.00
  10.0%
