Build Thread 1986 CJ7 Build
Ha! Nah on the 4:1 gears. It did cross my mind though.
Do you have any popping out of gear issues with yours?
Did that couple years ago and went up to N Carolina this last late April early May and we did some different trails and back roads. Popped out once and I didn’t know what happened at first. Thought maybe it did something to the dive shaft or something else happened. Nope got back in and shifted back in. I did use the heavy springs ball kit. Who knows
Good observation. I've put 3/8 npt plugs in there before. Be very careful when you tap and check the fit often while tapping so the hole doesn't get too big and you end up with a bad fit or the plug sets to deep.
Also, drilling close to to the end of the casting makes for a weak spot to crack if ever hit on a rock when crawling
Thanks fellas. I’ve sourced a couple low profile socket plugs, with magnet, and plan to do it this evening. Finally above freezing here too.
A bit of research says Dana did have a drain there, up to about 1970+\_
Maybe someone with an early CJ (pre ‘76) with Dana 44 could verify?
That would have been a nice added feature on the 20 axel also. But nooooooo. Don’t see any place to add it anyway after the fact.
CJ: which seal are you referring to?
You had a worn groove, just space it out a quarter (,250) inch and you can save all your parts.
I'm so old school that I fix not replace everything.
Had a nice talk with K.
We came up with something...
One year ad free here,,,,
Jeopardy type annswer, 'What is a case spreader?
Removed the T-case. Lotsa nasty, oil-caked, red sand to deal with
Not sure how well you cleaned the under carriage after your trip to Utah, sounds like it could be Moab red. I'm still finding it under mine nine months later :)
Red for me ips GA clay ..Nasty
Wondering if that’s the backside.
