225 V6 smog pump holes in head?
rocmoc
Tucson, AZ & Mexico (both Mainland & Baja)
1970 CJ5, V6, 3spd, power steering, headers, electric fans, upgraded larger radiator, '78 grill, disc brakes (front only), swing pedals, hyd clutch, extended front shock mounts, upgraded front driveline w larger u-joints, warn OD, D30 front diff, lockers, 2100 carb, working on a '74 tub replacement, '78 windshield frame with '78+ Acme hardtop
'70 V6 225 cu in, original engine. Previous owner removed smog pump and installed regular bolts into the holes in the head where the lines pumped air/fumes into each cylinder. Smog pump not required where I live so will not be reinstalling the smog pump. What have others used to plug the holes? I picked up a set of plugs that were suppose to work but the end is too long so can't reach the threads. The threads were correct but plugs must be for a deep hole. For now the standard bolts remain and the engine runs great. Just looks like bad.
rocmoc n AZ/Mexico
If the bolts will back out easily mark them and cut off the extra then reinstall. I have seen a lot of bolts that were too long sticking out of the exhaust manifold when the pulse lines have been removed.
Found out today the plugs are correct. There is an insert that has to be pulled out of the hole to allow the plug to seat all the way in. BUT how to get out the insert?
rocmoc n AZ/Mexico
$35.00
  17.5%
