232 not starting
232 not starting
Allen
Lexington, NC
75 DJ5 (that's right, a DJ!)
232 Straight 6, automatic
No mods, just trying to keep it running.
Yes, it's right hand drive
I am trying to troubleshoot why my Jeep will not crank again. I have replaced the timing chain and coil, I am getting spark, and fuel (well, only fuel when I pour it in the carb, I think I have a plugged line-I pulled the pump off and it checked out fine). Anyway, with the '75 AMC 232 i6 where should I begin to troubleshoot? I have adjusted the distributor forward and backward to adjust the timing a bit, and the jeep will turn over as long as the battery will let it, but it just will not fire, I am getting a few "exhaust puffs" out the back, not the loud backfiring I was getting before replacing and reseting the timing.
On a similar note, anyone around Lexington, NC want to swing by and drink a few beers and figure this one out?:D
Hey Man...
Only thing I can think of is to double / triple check the timing and firing order (I've done wrong before while reading it out of the book and spent days trying to figure out.);)
If you are getting spark, and you're dumping fuel in, it should fire. As they say, should is a very loose word :cool:
I suggest playing with the timing by hand, and double checking firing order.
Past that, any chance we got distributor on the wrong tooth whilst doing timing chain stuff? :confused:
:confused: Thought he meant wouldn't start, but did say in beginning wouldn't crank... :confused:
Let us Know Allen... :popcorn:
~ JR
Thanks JR74CJ5. After re-reading the post I think your sugustions are more on target. Lets let Allen clarify.
The starter is doing it's job, the jeep will crank over until the battery dies, then I recharge it and try some other things. It's just not "igniting" the fuel and continuing to run on it's own. I'll try moving the wires around and rechecking a few things, will let you know if I come up with anything different.
The misunderstanding was my fault. Now that I am on the right track I would try double-checking the timing. Then check the spark plug wires. The distributor rotates clockwise. From the #1 plug the firing order is 1,5,3,6,2,4.
Let us know how it goes.
I made some "progress" this evening, after blowing out the fuel line and switching the plug wires to the pre-74 combination I actually got the engine to puff through a couple of cycles on its own. Then it backfired very loudly (like a gunshot), I decided to call it a day there and am now happily into my second local brew. What should I do now? I am getting fuel, and spark, and it appeared briefly that everything was coming together, what does the loud backfire indicate?
(when I first started going through the engine it had bent pushrods, and was out of time, I have replaced the rods and timing chain and checked to make sure it was in time) The jeep is a '75 model, but this is the second motor in it, and it may be from '74 or earlier.
Backfire sounds like you have a timing issue. but then you said you had bent push rods. How are the valves?
Do a compression test
    Best for votes
    on specific items
    Best for votes
    on specific items
$45.00
  22.5%
