232 still wont run in my 77 CJ7 ???
It can happen, especially when the new cap is in the hand and the old cap is still on the distributor. Accidentally turn the new cap 180 degrees in your hand & you've started a whole new ballgame that looks just like this.
Not a prob. All we gotta' do is figure out which tower really belongs to the #1 spark plug and plug that one in. From there, just follow the standard firing order all the way around & it'll come up right.
When you get to it , please check all the wires and see if they go to the plugs in the proper sequence even though 6 is now 1.:cool:
Nothin' at all half-axed about moving the plug wires to get it right... turn the distributor and which way will the vacuum advance point? It SHOULD point toward the front of the motor. You can pretty much pick the position of the distributor according to your whim, long's the wires all go to the right towers on the cap.
The vacuum advance right now its pointing towards the front of the motor, so before i put the timing cover back on should i turn the crankshaft sprocket from where it right now 2 full turns and then see where the dizzy is sitting then?
I am thinking about the next guy that has the misguided idea that the little 1 on the top of the cap has some meaning.
You guys have started to confuse me ha, and i thought the little 1 on the top of the cap did have a meaning, so what do you guys think i should do right now while i have timing cover off and the new timing set on? Like Tim said, while the two timing marks are pointing at each other it is on the COMPRESSION STROKE, because thats the only way the CAMSHAFT sprocket will go on correctly, and it is on correct right now and tight along with the crankshaft sprocket, if you want i can always snap a picture, to show you the dizzy with the timing marks lined up and the timing gears to, but the picture in my previous post is the old gears lined up and that comes back to Tim's comment as they only go on one way and i took them off and put the new ones on the same way as the picture shows in the diagram and the picture i took. So at this point what should i do? Rotate the camshaft sprocket two full turns and see where the dizzy is? or put it back together and move the dizzy itself? or what?
Please take us some good quality pic's. from close up to a farther away view. I think it will help us, it will help me anyway.
If you turn the camshaft one full turn, it'll turn the distributor one full turn, too, and wind up exactly where it is now - the distributor is always in agreement with the camshaft, while the camshaft always turns exactly half as fast as the crankshaft.
I've seen all sortsa' goofy markings on distributor caps, some of which bore some connection to reality & some of which didn't. I've also seen LOTS of distributor caps with no markings at all. I'm thinkin'... if we rotate the distributor 180, won't the vacuum advance bang into the side of the motor?
Just for just-in-case, let's look at one photo of the two sprockets with chain, complete view so we can see the whole picture. I'm pretty sure it's right, though.
Then... I vote we pick the distributor tower that the rotor points towards and put #1 spark plug wire on that tower, then work around the firing order from there. If it makes anyone feel better, we can scrape the "1" off the distributor & put a new one on with a White-Out pen. :)
EDIT: For reference' sake, I've also got two I6s out here I can line up to TDC1 and pop the distributor caps off & take pictures of where the rotor points.
EDIT II: Oh, for beans sake. If we rotate NOT the WHOLE distributor, but only the SHAFT, 180 degrees... it'll plug right back in & engage the oil pump and point toward #1 tower, won't it?
I would like to see where the vac. adv. is pointing now.
Bingo!!
Corey, I have one more question just to confirm what I think I know?
Is the plug wire that is attached to the spark plug in the #1 cylinder in the tower that is in the #1 position on the dizzy cap? Or is the #1 plug wire attached to the tower in the #6 position on the cap?
The plug wire that is attached to the #1 spark plug from the number one spot is attached to the cap on the number one spot also, so yes it is.
Mine looks identicle to the diagram posted above, its just very hard to see the timing mark on the smaller crankshaft gear because it isnt white, my camshaft sprocket is pointing at 6 and my crankshaft sprocket is pointing at 12 so it is 100% identicle to the picture. But if you look at the pictures that i posted my Dizzy is pointing 180 degree's opposite of the way it should be, because my engine is timed like the picture and description says and the dizzy is pointing away from #1.
I am going to suggest that you do as Tim suggested and pretend that the #6 tower is the #1 tower and wire the plugs accordingly, make the engine run and we will reset the dizzy another day, like tomorrow , maybe.
The #1 on the dizzy cap is what is called a “convention”. This is like a red traffic light you know to stop and when you lift the turn signal switch you can expect that the passenger’s side turn signal will flash. The convention was ignored some where along the way and you got caught by it. The #1 wire lines up with the #1 tower and the #1 on the cap so the mechanic, in this case you, won’t have to find top dead center compression just to do a tune up and check the timing. I bet it is interesting to put timing light on the #6 cylinder and expect to get a valid reading. You have done well with this project. Ataboy.:cool:
It looks to me like your valve timing (sprockets, chain) is exactly as it should be, and the front of the motor's ready to be buttoned back up.
Now - as to the distributor - your choice. Either (a) swap each pair of plug wires at the distributor cap or (b) pull the distributor, rotate the shaft 180 degrees & plug it back in, then retime the ignition. Just to triple-verify, you could hook up your trusty timing light after you get the front of the engine buttoned back up and "try" to time it... as the ignition now is, you shouldn't be able to see the timing mark at all with the timing light connected to #1 plug wire, but if it's connected to #6 plug it'll appear to time correctly.
WHILE WE'RE HERE & TALKING ALL THIS THROUGH... let's verify one more thing. #1 spark plug is the FRONTMOST one, nearest the radiator. The REARMOST one, nearest the passenger compartment, is #6. Just so everyone's dead sure. :)
Well all looks good in the chain world.
I just want to know COREY, is how did it ever run like this to begain with.
Is IO right about the UFO's :eek:
I do have to agree with IO on turning the dist. so #1 is where #1 belongs.
Well ok then thats all i was waiting for was one conformation from a few of the many guys i know can give me a dead straight answer :) especially after looking at my pictures, time to go put everything back together then grab my chiltons and start switching all the plugs across from each other.
Tomorrow would be a good day to do the Dizzy, my so lucky week takes a turn for me on thursday, i have to go get my other two wisdom teeth pulled :mad: because the navy didnt pull those ones. But i got a job today at a landscape place and could get another job at a warehouse till i start school this fall for diesel technology :)
It ran great before all this stuff, i could not tell you how the rotor turned 180 degree's :confused: my dad took the old one off and put the new one on, so it could be possible that the rotor wasnt down tight enough?:confused: i didnt take if off so.. it isnt my operator error
and Tim how would I retime the ignition after moving the dizzy?
Lets have a really good look at that rotor!!:cool:
Once we get it confirmed running, here's whatcha' do: Loosen (actually remove) the bolt holding the distributor in place. Note which direction the distributor is pointing. Unplug the vacuum advance hose, pop off the distributor cap.
Lift up on the distributor, slowly. The rotor will rotate as it lifts, as the gears disengage at the camshaft. At a certain point, the rotor will stop rotating - the gears have cleared each other. Stop there.
Now hold the distributor at that height with one hand while you turn the rotor 180 degrees (either way) with your other hand.
Lower the distributor again with the rotor pointing the new direction. It'll smoothly engage the gears again, and the oil pump's drive. When it's fully bottomed, bolt it back down again, just tight enough to adjust it for timing. Plug the vacuum advance line back in, snap the distributor cap back on.
Don't forget to NOW have the plug wires plugged back in according to the "1" mark on the cap. That'd be correct now.
From there on out, time it with a timing light, just like reg'lar. Clip the light onto the battery, snap the snap oil onto the #1 plug wire, disconnect the vacuum advance hose, crank the engine. Under the strobing timing light, the mark on the balancer should line up nicely with the "8" mark (8 degrees BTDC). Twist the distributor to get that to happen. Tighten it back down again, reconnect the vacuum advance hose.
I really don't think the rotor got turned, not this time around. It may have BEEN turned for a long time, but the plug wires plugged in to match it. THIS time around, the wires may've just gotten plugged in "right", which was wrong. :)
