258 build
258 build
Boulder
1985 CJ-7. guess it has an 89 straight 6 with weber crab. Auto trans and transfer case (not sure what but stock [maybe 300 on the transfer]) open diffs. Hard top and doors
Good day to all, I just pick up a used AMC 258 i6 / 4.2l (258) block. Well I got a few other things with it but its all going to get tore down an rebuild. I been researching other builds an haven't found anyone that's used the F.A.S.T. fuel injection system yet.
http://www.fuelairspark.com/fas/ez-...ystem-master-kit-w-inline-fuel-pump-kithtml/]
If i missed a post about it sorry. Please point me in the right direction an if you can give me some search pointers, cause I tried many different combo's
So the build plan is to do the minimum amount of machining, change the cam an switch to the 4.0L head. I would like to do a header of some sort an maybe a different intake. I still have a lot of research to do on all of this so if you have any input it would be much appreciated. I like the fast system because it doesn't call for a different or another computer. It also seems like a little easier to work with and on. I know i could just get a donor jeep with the head an injection stuff on it an have all the parts but it seems like a lot more work. Cheaper yes, but also more things to go wrong. I also don't have to worry about emissions as by the time it goes in to my 1985 CJ7 , it should be exempt
So if you have any thoughts, experience or places to do some research please send them my way
Sent from my ASUS Transformer Pad TF700T using Tapatalk
What intake are you going to use for the 4-barrell, Offenhauser?
I hate Bosch O2s since they caused me so much trouble. That may be only with 4.0 systems though.
Gotta remember that the AMC 258 i6 / 4.2l /4.2L is a tractor engine that's redlined at 4500rpm in stock form.
I would put my time & $$$$ into a AMC 401..........
Not sure what intake yet, I'm not sure whats available for them. Would like to stick to the inline 6, has i have it. Plus TF999 would probably have to be swapped adding another expense. Also I don't see a need for V8 power. It will be a DD til i have kids, so having a V8 just to drive around boulder seems over kill. Also, maybe I'm wrong, but i think switching to a V8 would mean changing axles cause i would start to break parts in the Dana 30 an AMC20 . Not that they wont break behind the AMC 258 i6 / 4.2l more with more power comes more problems:-)
AMC put 8's in CJ for years with the same axles you have.;)
I know Boulder Colorado well(born in Colo.). At your altitude, an '8' is nice for the power on the hills.
Your choice/your money to build up that 6--Just not the way I would go.
Good luck,
I understand the route your taking with the quick plug and go injection system but have you tossed around putting in a 4.0? It is more work on the wiring side but less mechanical work than you have planned. You could then spend a little more as you are planning on doing anyways and get a pre-made wiring harness.
However, there are some minor customized components you have to work out like the power steering lines, fuel line and exhaust pipe connection.
I had a 4.0 XJ when I lived in Boulder and it performed awesome whether along the front range or up in the mountains.
Cool vid-THX
Here should be the link: http://www.fuelairspark.com/fas/ez-...tion-system-for-jeep-6-cyl-w-fuel-systemhtml/
Seems like a decent system. Definitely an alternative to Howell and MoPar.
I'd want to ask them how much cam could be run with it. Put it on a good flowing intake manifold, and add some decent headers, you might be able to build yourself a screamer.
What size tires, and axle ratios do you plan on running?
