258 camshaft excessive endplay knock
Goatboy4570
canada vancouver island
!983 CJ-7 258 locker moly axles 33's 4" lift MM hubs MSD/HEI 2100, 1990 YJ 258 31's.
78 Jimmy 357 Vortec 4 spd 205 lockers 33"s striped down, 63 F100 unicab 454 4spd RatRod, 87 S10, 88 S10 310V8, 87 Chev 3/4 ton, 80 Caprice Landu Coupe, 86 Monte 355 stock car, 1978 Monte 383 Vortec 4spd Slammed 10" rims Satin Black, 79 shovelhead OS chopper, 84 nighthawk, 88 CR500, 79xr500, 99 Susuki LTF500, 2010 Doudle bug 212 predetor. oya 2005 P71
i would like to hear from anybody who has delt with this problem.
Apparently theres a retrofit spring and bolt kit and the problem is not that uncommon to 80s motors.
I thought it was my water pump failing but its the cam touching the inside of the cam cover.
my chain doesnt seam that stretched when i do the grab the lower crank pully and jog it back and forth test.
Info or experiance
It is probably stretched, you will also notice indentations on the top timing gear teeth, it is probably one of those nylon tooth jobs also. I would suggest replacing it with a full steel timing gear. When you set the ignition timing previously, the timing marks were probably bouncing around quite a bit also. I was not aware of any retrofit spring and bolt kit.
Engine Oil
