Engine 258 Engine brackets
DADSOLDCJ
Chesterton, IN
'76 CJ5, 4.2 I6, T150
Are they the same mounts that were on the old frame? What misalignment issues you having? If it’s the fact that the Transmission mount is too far forward or aft, it’ll be you crossmember. There are several versions out there, and the frame may not be drilled for the one you are using.
Also - And I may be totally wrong on this - but I was under the impression the AMC 258 i6 / 4.2l used a small frame bracket on both sides and the V8’s used a small and a large. That’s the setup I’m using with a AMC 304 , and my one memory cell says the 258 didn’t use the large one......
