258 exhaust manifold heat riser removal
elwood blues
Always Off-Roading Jeeper
Export, PA
1978 CJ7 4.2L Comp Cam & valve train, MC2100 carb, MSD ignition, Dana 30 front, T18 trans, Dana 20 txfr, AMC 20 rear.
You can always tap threads into the holes, then insert plugs. Contrary to what some people might think, cast iron is actually fairly easy to drill and thread.....just use a high-quality tool and a good amount of tap oil.
I would leave it, it helps reduce warmup times and cold weather performance.
In the "open" position it provides little restriction.
That's not an option, its already gone.
i agree with les.. since its gone and your at a point of no return.. drill and tap it.. :chug:
what if you just put a bolt all the thru and then put a nut and washer on it
I know its a little late but I just stumbled on it
I know this is almost a month late, but I did end up simply tapping the holes. 1/2" 24 with header plugs, no big deal, no leaks, thanks guys :chug:
