Misc 1983 CJ7 Front Drive Shaft Removal Tool
CJ7Simon
Donator
Richmond Virginia
83 CJ7, 258, T5, D300, D30, AMC/JEEP TRAC-LOK
Called inverted torx
Thanks to both of you! I thought Torx as well, but all my Torx sockets are 6 point. The bolts pictured have 12 point heads. I believe my further research using Google AI has revealed what I need:
"E-Torx bits and sockets are 6-point, but M-Torx bits and sockets are 12-point, often used particularly for automotive, industrial, and high-torque applications, often used for specialized fasteners like CV joint bolts which allow for better positioning in tight spaces."
I've added this for anyone else who may need to know in the future. In the meantime, you did help guide me where to look. Many thanks!!
You tried a 12 point socket mm or standard socket 1/4 drive? Yesterday I had to buy mm set of Allen wrenches for a 3 mm Allen. It was in between 7/64 and 1/8. :biggun:
