258 head fitment
the only thing that comes to mind is that the head bolts are different sizes, diameter. but I am not sure how that would mess with this.:cool:
I went online and noticed gaskets for the 85 head only works for 83-87. I would what has changed.
It's head bolt diameter.
If what I read about the Cj's is accurate, somewhere between 83 and 84 they went from a 1/2" bolt to a 7/16" bolt.
It seems that the 1/2" version is more common. I had a helluva time finding bolts for the one I'm working on. it has the 7/16" bolts.
Note: In '84 there was a hardening issue with the head bolts. It doesn't affect all of the '84's. There's a serial number range. Although, I'd just replace them with some ARP bolts and not run the risk of breaking a head bolt off in the block.
Good to know. Thanks
I'll have the head drilled out to 1/2". Definitely will go with new bolts.
Engine Oil
