258 ignition ?
258 ignition ?
Bunky67
SW Michigan
1977 CJ5 304 V8 3 speed Trans Fiberglass front end,
I'm getting ready to do an engine swap in my CJ5 and I'm getting ready to purchase an engine and while looking at engines I ask about the ignition module and they keep telling me there is just one wire,
They must be talking about 1 wire coming from the control Box ?
Or Am I missing something ?
I'm going to assume you have a stock ignition setup in your 1977 CJ for the purposes of my reply. If this is the case, you should have have five wires coming out of your ignition control module utilizing two large plugs. The black wire goes to ground (-), the white and blue ones go to your distributor, the red one is the hot(+) supply from the ignition switch(which also supplies the hot side of the ignition coil, and the green goes to the neg (-) side of the ignition coil.
Hope this helps.....
