258 Main and Rod Bearing Size Identification
Rescue Diver
Full Time Jeeper
Kansas City
1979 CJ-7 with a fiberglass body and 1982 wide track axles, 258 I-6 with a 1995 4.0 head, HEI distributor, Motorcraft 2100 Carb, T-18 wide ratio tranny, Super Lift Springs and 33s, a 1997 BMW 328i, and a 2010 REDLINE CONQUEST TEAM Cyclocross Bike. :)
I'm doing a simple re-ring on a AMC 258 i6 / 4.2l I just picked up. I have the head at the machine shop for a valve job and I just tore down the short block. The rod and main bearings don't have STD, 010, 020, or 030 stamped on them anywhere??? They have the letters AM which I believe means they're factory American Motors bearings, but I'm not 100% sure. Besides that they have a part number that I haven't been able to find on the internet, and lastly, some have C-2 while others have C-20 stamped in them. I was thinking that C-2 or C-20 might mean they're for a crank that's been turned undersize, but guys at two different machine shops don't think this is the case. The shop that's doing the valve job looked at two of the bearings I brought in without measuring them and said they think they're STD because they have no size makings.
The main bearing has part number 3186677 and the letters M C L,
The rod has X-3230785 on the opposite side from the C-2.
Since this is a Jeep forum, I thought it would be a good idea to ask on here. Has anyone else that's done an overhaul of a 258 seen these bearings that can tell me what they are?
Can someone please tell me what the factory size is for the rod and main journals so I can try and dig up a micrometer?
Since the old bearings still look nearly new, and the crank is smooth, I was just planning to buy the same sized bearings and check the clearance with plastigauge without paying a shop to polish or turn the crank, but this has thrown a wrench in my plans.
Download this PDF and see pg 286:
http://oljeep.com/JeepEngines.pdf
Also, Some info I found that may help you narrow your search:
"There are two generations of 258 engines. The first generation was introduced in 1971. This earlier engine has cast iron intake and exhaust manifolds with the two manifolds bolted together by 4 bolts and a gasket between. In 1981, AMC revised the 258 for lighter weight. A new block casting and fewer crankshaft counterweights were used. A new smoother exhaust manifold and aluminum intake manifold were introduced. V-belts were replaced with a serpentine belt, and a new lightweight plastic valve cover was fitted. Although these two generations have the same bellhousing and motormount attachments, and are mostly the same internally, the differences must be kept in mind when choosing used replacement parts.
The 258 can be identified by the 4th character of the engine build date code ("A", "B", "C" or "M"), stamped into the engine block below and between the number 2 and 3 spark plugs. An engine stamped with "B" is an early 258 with a 7.6:1 compression ratio. "A" and "B" are engines with 1-barrel carburetors, while "C" and "M" are 2-barrel. "M" originated in Mexico. Other codes ("E", "F", "K" and "L") are 232 engines."
From pg 286 of above link:
CRANKSHAFT
The 4.2L crankshaft has twelve counterweights; the
crankshaft is counterweighted and balanced independently.
It has seven main bearings and six connecting rod journals.
The crankshaft has a main bearing journal diameter of
63.489-63.502 mm (2.4996-2.500
1 'I), and main bearing
journal widths of (No. I ) 27.58-27.89 mm (1.086-1.098"),
(No.
2) 32.28-32.33 mm (1.271-1.273"), and (Nos. 3, 4, 5,
6 and 7) 30.02-30.18 mm (1.182- 1.188").
The crankshaft has a connecting rod journal diameter of
53.17-53.23 mm (2.0934-2.0955") and a connecting rod
journal width of 27.18-27.33 mm
( I ,070- 1.076").
The component parts of the crankshaft assembly are
individually balanced; then the complete assembly is
balanced as a unit.
Note:
On automatic transmission equipped engines, the
torque converter and converter flexplate must be marked
prior to removal and installed in this position upon
assembly.
Service replacement dampers, crankshafts, flywheels,
torque converters and clutch components are balanced
individually and, therefore, may be replaced as required
without rebalancing the complete assembly.
If the crankshaft is damaged to the extent that
reconditioning is not feasible, it must be replaced. The
engine must be removed from the vehicle for crankshaft
replacement.
For more crankshaft specifications, refer to
4.2L Engine
Specificutions, 'Engine Assembly' section of this chapter.
CRANKSHAFT MAIN BEARINGS
The main bearings are steel backed, sintered copper, lead
alloy precision type.
Each bearing is selectively fit to its respective journal to
obtain the desired operating clearance. In production, the
select fit is obtained by using various-sized, color-coded
bearing inserts.
When required, different sized upper and lower bearing
inserts may be used as a pair; therefore, a standard size
upper insert is sometimes used in combination with a .001"
undersize lower insert.
Service replacement bearing inserts are available as pairs in
the following undersizes: standard, .001",
.002", .010", and
,012". The size is stamped on the back of the inserts.
It may be necessary, in some instances, to use different
sized upper and lower inserts to reduce clearance by
.0005".
The bearing insert nearest to standard should always be
installed in the upper location.
Caution:
Never use bearing inserts with greater than .001" difference in size in pairs.
Upper
- Std.
Lower - .OO 1 'I undersize
Thanks! That manual is awsome!
Archive Master.:notworthy::notworthy::notworthy::notworthy:
