3.8?
3.8?
belandscj
newengland
85 cj7
The buick v-6 was called the Dauntless Buick 225 V6 225. Around 74 or so it became a 231. Neither motor was around in 85. A stock 85 wouldve used an inline 6 cyl. known as the AMC 258 i6 / 4.2l . That wire is for an electric choke.
computer controled carb [/QOUTE]
Computer controlled carb??? Like Throttle Body Injection? I don't understand, is that a swapped in motor?
Because that looks like the +12V wire to the choke. All it does is heat up the spring element inside the choke.
That carb looks like a singe barrel Carter YF.
$125.00
  62.5%
