4.0 conversion cps ????
lj97
plains mt.
74 CJ5 , getting upgrade 4.0 & referb on body & drive line
Picked up my donor vehicle last weekend.4.0 sounds excellent . donor is a 2000 rolled Cherokee with auto.
Getting mixed opinions on cps sensor. Been told both ways on sensor. Auto Transmission or manual trans does it make a difference? I'm thinking no. Then get a different bell housing off late model ( clutch issue)really don't want internal hydraulic, or modify my bell housing for cps or use my bell housing with hesco front cps convertion.
Do I need to be an electrical engineer to pilfer the harnesses out of the Cherokee?
A little feed back or direction for information would be appreciated, Thanks
Oh by the way this is going in a 74 CJ5 with a T-18 trans.
Thanks ,
My donor is a 2000 but I'll drop him a line to see what he can come up with
Getting mixed opinions on cps sensor. Been told both ways on sensor. Auto trans or manual trans does it make a difference? I'm thinking no. Then get a different bell housing off late model ( clutch issue)really don't want internal hydraulic, or modify my bell housing for cps or use my bell housing with hesco front cps convertion.
Oh by the way this is going in a 74 cj5 with a t-18 trans.
AUTO or Manual CPS doesnt make a difference it is the same part. It is just a magnetic pick up that is excited but the flywheel/flexplate teeth.
After 99 the motor mounts on the 4.0 changed. So a 99+ engine will not be a direct bolt in affair like the 98 and earlier 4.0s.
I have never done a OBDII harness but I can guarentee its going to be a challenge. I have been building OBDI harnesses and could probably do an OBDII if I applied myself to it but it would be a bear even for me. If you are not very familiar with wiring diagrams, its going to be a tough process, especially if you want to remove the excess wiring from the harness.
I have considered converting to a coiless 4.0 setup because it is just way cooler but ultimately in my own project I decided that the simpler OBDI setup will be a better way to go as I have figured out how to get the ecm to stop throwing trouble codes due to the swap.
I would suggest that you grab an OBDI setup and convert it to suit your purposes as a learning experience. Once you get the jeep running you can take that experience and use it to figure out the OBDII wiring.
