4.0 Head, MPFI, and Serpentine on my 82 258
dalefan88
Crazy Sr. Respected Jeeper
good job man
you just probally made half the people on here want to do that. just start it up and go. dam i can never do that even with my motorcraft carb.
Still hasnt hit below freezing yet but its been getting pretty chilly (according to my Alabama standards) and so far no issues at all. Starts without having to tap the gas at all. In contrast my wagoneer which is still carb could not run worse. It seems that as soon as we made the shift from warm cool to cool cold weather the wagoneer has run like dog do which it normally runs smooth and good. Its also a huge PITA to get it to start and stay started and it definitely is very reluctant to move until it gets well above the blue.how does it start cold? and hows the power?
congats to ya. I cant wait till I can get mine converted.![]()
You said earlier that you used a CPS out of an XJ? How were your able to mount it? I have a 78 CJ7 and would love to do this conversion, but the kits for CPS are a little steep right now. I have everything else out of 92 cherokee and if I could find a way to use that Crank Sensor, I may do this conversion real soon.
I was looking back over the thread and saw I forgot to link the article I was referring to hereHere is some reading from JP on the horseshoe style intake and 4.0 heads.
They say they lost HP when bolting one onto a 98 xj. I don't feel much of a difference with mine I want to say its a tad easier to maintain 5th gear but that could be in my head.
Got the clifford's spacers today.... for 33 dollars you get 4 spacers not 14. I called cliffords and was like "WTF" and they said that you just put two in the front and two in the back and thats all that is necessary.... I don't like it I think that it would make more sense to center all the bolts but whatever cliffords knows more about engines than I.
I used carbe cleaner to clean the mating surfaces of the block and the head and also cleaned the top of the pistons and the cyclinder walls. Then (since I have my Battery tray removed) I stood on the frame and dropped the head in placeTorqued the bolts all to 85 FT/LBs with the exception of #11 that got a little locktight on the thread and 75 Ft/LBS
So so you need these spacers? I have seen swaps with and without them?
If you have any AMC 258 i6 / 4.2l that was made after jeep switched to the smaller headbolts then you woo need them
