4.0 Head, MPFI, and Serpentine on my 82 258
Was the other fuel pump from the 4.0 in tank?You could put a elec pump back by the tank with a large pre filter like Howell Inj does it.Depends on what it needs for fuel press to determine pump sizing.I think thats what your talking about when you say fuel delivery
Mike
Well yeah I just am worried about it is all. I have a handle oon everything and a thorough understanding of the components engine wise and wiring just not fuel. I read the inlines tend to go bad and that has me concerned. I was thinking about getting a intake pump for a 94-95 cherokee and dropping my tank and installing it on the assembly. But intank pump or inline what about the fuel lines?Will i have to redo all my hard lines on the sending side as well as all the rubber lines.. Questions like that.
I am getting ready to install a inline pump into my carbed waggy. And that is supposed to be super easy according to everyone online. But I was under there today before the rain hit trying to figure out where the heck to put it. My hardlines in it run from the tank almost all the way to the power steering box before the soft lines start. So I guess I am going to have to cut a section of the hardline out under the frame.:confused: Fuel delivery and A/Cs just confuse me I guess.
OOHHHH, this has me itchin to to the 4.0 head swap. Cant wait to see the wiring part. :)
I was just thinking about it and I am going to be pretty ticked if I can't get this to run or I blow the head gasket or something when this is all done. So far it has been a little too easy.:pissed:
If you are still worried about your fuel issue, I would get a relatively high pressure electric inline pump and use a regulator in the engine bay. This way you wont have to worry about inadequate pressure and you can dink with it if it's not just right. Also I hate dropping the tank to get at the dang pump if something does go kerflooey. Just remember that most inline pumps are pushers- not pullers- so it will have to be as close to the tank as possible.
Good luck!:chug:
Good luck!:chug:
Well here are the issues... First the original cj lines run down the pass side and come up on the pass side of the block. I guess this isn't too much of a problem because I see no reason why I just can't get a super long fuel injection hose and run it from the hard line to the the fuel regulator and it could follow the same path as it would have with the mech pump.... But can I reuse my hard lines? I mean I would think since they are metal that the higher pressure (i think i read online I needed a 60 psi pump and a 40 psi regulator?) but I am no expert and no one really puts a lot of detail into the fuel delivery in the write ups.
Also do only rubber hoses between the fuel pump and the engine need to be upgraded, or do you also have to change out any that run from the tank to the begining of the hardlines?
I was thinking intank but an inline sounds more servicable. But why do people claim you need to keep a spare at all times? Do these have that poor service life? I mean a good quality one is close to 90 dollars so to get a spare and a primary you are looking at 180.
My other concern is the fact that I only torqued the head bolts to 85 Ft/LBs which is the torque spec for an 82 CJ7 with 7/16 bolts. But hey if IO hasn't had any issues with it I guess I shouldn't worry.:chug:
for the rubber line i would run all fuel injection hose. the hard line should be fine if there not rusty. if they are i would replace them. fi hose i not cheap. i work at advance and its about $5 a foot.
I think people keep spares just to have it.If you put a large fuel filter on the suction side you should be fine.Mines mounted on the frame close to the tank passenger side.Its been running for 12 years no problem.Just don't get a cheap one locate it close to the tank.If you can try to protect it with something.It'll probably run you a 100 plus for on.Ask Dale Fan what one costs and a regulator
Mike
i know a good inline fuel pump is about $90. tell them a external mounted one on a say i think 86 ford f150 and check the psi on the box and we do carry other one just hope you get a good parts person cause the others are not in the computer. people at work always come to me cause i know which one it is. i would have to check on the regulator. which one will he need?
Slick setup.Did the 4.0 quit running water thru the intake.I didn't notice any hose openings in your pic.
Mike
Mike
No they quit doing that. I think that the fuel injection negates the need for that because you no longer have to worry the intake heatin up the gas too much. Interestingly enough I did not have to buy any new heater hosing to bypass the intake. The original hosing was long enough.
I am following this thread alot:
Jeep Strokers • 4.0 head and EFI on a 4.2 block
I am going to buy the e2000 pump like this guy did. I am not however going to buy the hesco fuel pressure regulator because that is insane at 189 bucks unless you are running a stoker or drg race engine.I am gettin the hesco fuel pump but that is because I found a brand new one locally for 60 bucks.
I am going to put the pump inline with the top of the tank and install the filter before the pump and run fuel injection rated hose to the stock metal line on the pass side framerail. Then i am basically going run fuel injection rated hose from the end of the hardline to the fuel pressure regulator and fuel rail following the same path as it would have before. I know it will be alot of fuel injection hose but its better than running goin throuh the trouble of rerouting the whole line to the drivers side.
If I moved it to the driver's I would also have the added concern of having the sending lines on the same side as the exhaust and there would be an increased chance of vapor lock or ,heaven forbid in an accident and the computer doesn't shut down the pump, gas spewing onto a hot exhaust pipe. Not to mention extra head ache.
I also am going to install the fuel pressure gauge like in that write up becaue it is a good idea and will make it alot easier to rule out fuel issues in the event I can't get the vehicle running.
I put a PDU in my 77 for the headlights and electric cooling fan and anything else that comes up. The only "high current " I have on the inside of the fire wall is the heater fan.:cool:
As of right now we have isolated everything except the fuel pump wire. Ojcwe do that then we will install the pump try to turn the engine over.
