4.0 valve cover "steel inserts" and grommets
Dep
ohio
1985 CJ7, 258/4 speed.
I just recently did the 4.0 head swap while my engine was being rebuilt. I dont recall any steel inserts or grommets when I took my AMC 258 i6 / 4.2l cover off. Does anyone know where I can find them?
What are they for? I'm just trying to picture what parts you are needing.
i believe they go on top of the rubber grommets on the valve cover, the bolts go through them and it holds the cover in place... in a nutshell
Are you using a stock 4.0 valve cover? Dont recall any inserts when I did my swap
Yep, stock cover. I can probably get away with using washers on top of the grommets....
the inserts your talking about i think are on 4.0 cover and is a dealer only part. last time i needed them in a pinch i shot to the scrap yard and grabbed them. its really an isolator. a washer would crush the seal
Yep, I think i'm late to the party. Cant find them anywhere. tinman , the holes in mine are almost as big as the head of your bolts...
Oh, I'm no help then, don't know much about the 4.0 after '95!
The grommets came with my felpro cover gasket but I don't remember if it included the steel inserts. I didn't size them up but the inserts seemed the same as those on the AMC 258 i6 / 4.2l . You have your old one to grab from?
once again thats a dealer only item. And i believe you gotta get the bolt,insert and grommet as one,not cheap. which is why i got them from a scrap yard.you can get just the grommets with an aftermarket felpro valve cover kit for that 4.0 you got, AMC 258 i6 / 4.2l never used them.
