Another update. I added a twin stick setup to my
Dana 20 . And I am also making the switch from my
T-18 to a SM420. With my 350 the rock crawling wasn't terrible but it is hard on the clutch. The 420 having a deep 1st gear (7.05:1) will give me much lower crawl ratio and is cheaper than doing
Transfer Case gears. Here are the specs from my
T-18 to the sm420 for comparison:
T-18 /
Dana 20 - 4.02:1(1st) x 2.03:1(low range) x 5.13(axle) = 41.86:1 crawl ratio
420/
Dana 20 - 7.05:1(1st) x 2.03:1(low range) x 5.13 (axle) = 73.41:1 crawl ratio
If I feel like this is still not low enough, I can always add the t case low gears in the future to get 113.92:1 crawl ratio. I do play on upgrading to 39.5's or 42's
Anyway, Christmas came early for me courtesy of Advance Adapters. Technically I bought this
Transmission and adapter for myself.
Muncie SM420 upgrade has begun.
I already tore down my
Dana 20 and removed the shift interlock pills for #FrontDig. I should have this thing all together tomorrow and should be able to start making a custom transfer cross member that will give me 1000% more protection over stock. I had to make a custom pilot bearing removal tool out of a bolt. I used the wet paper trick again and it worked as it should with the diy tool.
I also got a new
Transmission tunnel and have to customize it for my twin sticks and the sm420. So apparently I'm now a sheet metal worker too.
Send me your thoughts and suggestions. I'm always open to them
I'll update as I remember and as time goes on (obviously).
