Steering 74 CJ5 Power Steering Conversion
RicksRadio
Iowa
'74 CJ5 , 225 V6, T14, D20
Existing manual gear box has 3 bolts, new or remans power units have 4 bolt. Is there a junkyard source that would have the proper frame mounting bracket for the power gear box?
Or perhaps, would the 4 bolt version have 3 holes already lined up and just needing to fab a spacer for the 4th on the existing frame mount? Thx
Jeep is definitely a 74 but someone had put in the V6 and it's drivetrain . Junkyard scribbles in wax or chalk crayon still on engine block from a '71 CJ5 . Also, the Transmission crossmember is from who knows what and was modified to hang properly under the frame given the trans mount used. Plus, fuel line and other under the hood mods took place to use the engine along with slightly modified dual exhaust system apparently from junked 71. Code on firewall denotes a AMC 258 i6 / 4.2l engine was original. Whoever did the swap did a decent job and made it easy by using all the drivetrain from the 71. The Buick bellhousing and factory Jeep/Kaiser spacer is pretty well T-14 specific. Anyways, thanks for the link and I am still searching around more. Thought maybe a quick fix could be found while I'm still finalizing anything needed on frame suspension brakes before the new tub goes on.
