'76 CJ7 fuel filler neck - where can I find one?
AdamH
Charlotte, NC
'06 Rubicon LJ, '81 Scrambler, '06 Commander
I need a new fuel filler neck for my '76 CJ7 . As some of you know, a '77 and newer is a different design.
Any ideas?
neither
I need the metal neck. I have a new hose and to my knowledge and the various stores I have asked the '76 did not have a plastic surround.
The metal neck bolts to the tub on the left side with two screws, not in a round pattern like later models.
The top picture is correct. I need to find one of those. The one I have has seen far better days. I would even take a used one but can't seem to find one of those either!
At this point I may just keep working on the one I have and see if I can make it better unless I come across one. The issue is the PO messed with the lip of the neck - no clue why - so it is out of shape. The gas cap won't seal properly so gas leaks out when going up a hill or over a bump when the tank is full. The Jeep is at the painter now :D so I would like to get the gas leak fixed before it starts leaking all over the new paint.
I have tried the original gas cap and now on my 2nd new cap (different ones) to see if I can get them to fit snug and it just won't happen.
Collins Brothers had one. I have called them a couple times in the past and they didn't. My luck they got one in recently.
Received it yesterday... looks brand new. :chug:
