Build Thread 78 CJ5 Farm Find
I haven't updated for a while, because I haven't done anything major. Just been driving it every once in a while and enjoying it. I have been researching things and trying to decide what I should tackle next.
Since it has the CJ trailer hitch on it I did decide to wire it for the trailer connection. I think I've done it right. Everything seems to work. Now I can pull my small utility trailer around town for things like lumber and landscaping supplies without having to steal my wife's Highlander.
I also spent some time replacing two body mount bolts in the rear of the body. A previous owner had used standard steel bolts and washers and over time they had warped somehow and were now loose. I replaced them with grade 8 bolts and washers of the correct size and tightened them down. Now the body doesn't bounce around when I drive over bumps, which is good.
I've mentioned before that the Transmission bushings on the torque arm look worn and I'm guessing the Transmission mount and the motor mounts are shot as well. I'm thinking that might be what I replace next. I'm looking at a Prothane set of motor mounts and Transmission mount and bushings.
I had been driving the jeep and everything was good. I did decide that engine and Transmission mounts would be replaced next. However after a week of using the jeep to pull a trailer and bouncing it around our local park during setup of a festival I found myself without brake lights or turn signals. I replaced a blown fuse and flashers but they still don't work.
Looks like the next project will be delving into the wiring. I've been reading through posts and checking wiring diagrams. I'm hoping I can figure it out as I'd like it to be drivable again.
I had been driving the jeep and everything was good. I did decide that engine and transmission mounts would be replaced next. However after a week of using the jeep to pull a trailer and bouncing it around our local park during setup of a festival I found myself without brake lights or turn signals. I replaced a blown fuse and flashers but they still don't work.
I did this years ago in a truck I had pulling stumps out... turned out to be a simple fix as the rear wiring harness had a ground that I had broken off... once that was fixed, all things worked again.
The issue was the 10-20 hours of trying to figure out where the issue was ;)
cb
HOLY COW!!! What a difference from last fall. Completely different Jeep. No more backfiring, much smoother. Having a more complete exhaust made the tone super deep and booming, since it has an old cherry bomb on it. My patch jobs are on and I spent less than $15 getting it all reconnected.
It needs tuning and I'll do that later this week. For now I was happy with just driving it around to a few friends houses and filling up the tank.
Looking good.
Did you wind up changing the main shaft on the T-18 and ditching the adapter in the front?
Haven't used the T-18 yet but thats the plan.
So I've been driving it a bit. I've verified that there are no more engine or radiator leaks. Looks like my JB Weld fix as held. :)
I've had to revisit the exhaust connection between my new down pipe and the back half. My initial fix didn't hold and came loose and was super leaky. I've since tried a different solution, still going the cheap route since I can't weld yet and I don't want to spend for a whole new exhaust. It seems to be holding better so I'm hopeful.
I was right that it was rich. My plugs are all carbon covered. I've adjusted the float and set the idle mixture and tried a smaller set of main jets in the carb. It had 61s and I've tried 55s, but I think those are too lean. I've ordered a set of 58s and we'll see how that goes. If I can get it to where I think its about right I'll put a new set of plugs in and check them after driving a bit.
In the mean time I've put a timing tape on my balancer and this weekend will be attempting to put together a timing chart to figure out if my distributor is set correctly or if I need different springs. I've been trying to tune this mostly by trial and error and it would be nice if I had some data to go with it.
I've also ordered the parts to do part of the Team Rush upgrade. I know that will likely affect how much fuel I burn and I'll likely have to go through this again with the carb mixture but I figured I'd read a lot about it and how much of a difference it made and why not try it. I can always go back to the 61 jet if I need to. The jets are only $10 a set at O'Reillys. I can get them cheaper on ebay but I don't mind a little more going to a local shop.
Overall I've enjoyed this and I don't mind taking things apart again. The way I see it I'm learning a bit every time I dig into it. I'm hoping I can get it running well so I can drive it this summer and get ready to tear the T-18 apart.
Keep a close eye on those JB Weld patches.
The stuff goes soft with antifreeze contact and heat.
Will do. I knew about the heat. I put it on my old headers once and found out pretty quickly what heat does to it. [emoji2]
It turns out that I ended up going too lean and was having issues with it backfiring on acceleration. All of my exhaust patches were cheap and weren't holding. There was too much vibration and heat and it would burn through and soon I would end up with a huge leak. I finally decided to bite the bullet and pay to have an exhaust put on.
All new pipes and a similar glasspack muffler. Everthing is secure and it sounds just like it did, and more importantly no leaks. This has allowed me to finally get the carb set right and now I've got a new set of plugs in and will check them for color after a bit.
Unfortunately I've also been dealing with an issue with it quitting as if I'd turned off the key. This was new behavior within the last month. After fighting with it and not understanding what was going on I thought I had it figured it out after moving a heater hose away from my ignition coil wire. It was leaning up against the ignition wire and making it bend and breaking the circuit. I tested this myself and it died as soon as I bent the coil wire. Once I moved the hose out of the way and secured it everything was golden for the rest of the night.
Today I decided to drive it to work and it was back to quitting at random times. After some thought and more research I think my ignition module is failing. I had replaced it last year and it makes me wonder if my resistor wire has been removed by the PO. All the things I'm seeing have been described in posts and attributed to a failing control module.
After work I'm going to O'Reilly's to see about replacements and testing to see if I have the necessary wire. I'm guessing I don't and that is why I burned up an ignition module in less than a 1000 miles.
Crossing my fingers.
"I tested this myself and it died as soon as I bent the coil wire.":confused:
Are you talk'n about the 2 wires that 'feed' the coil or the larger dia wire that goes to the dizzy from the coil?
If it's the 'feed' wires-Not uncommon for a small gauge wire like that to have a internal break at the connector.
It was the large single wire from the coil to the dizzy.
I know I've got a wiring nightmare that I'm going to have to go through one at a time. I have a feeling that it might have to be sooner than I expected, but I'd like to be able to enjoy it this summer at least.
As I'm typing this answer something doesn't make sense to me that I think I need to go back and test again. I need to go back to this coil wire and make sure that it was making good contact. If the wire contact was far enough into the coil I wouldn't think it would make a difference if a small amount of sideways pressure was applied. I'll check that wire again this evening. These wires came from a crimp yourself set and while that coil wire end was pre-crimped and had the hood attached, I wonder if I need to pull the contact through the hood some more.
How long till the end of the day?
Just a bit of an update. Ok, the day after I posted this about the distributor wire I drove it to work. Major meltdown. Died repeatedly on the way in and similar on the way back. I tried swapping out coil and ignition module but no difference. I was so frustrated with it I didn't touch it for a few weeks.
I went back and checked for vacuum leaks but I was pulling decent manifold vacuum at idle so I didn't think it was that. I had also previously swapped out the fuel filter. I just didn't think it was fuel related.
I even pulled the dash off a bit to check for loose connections or frayed wires. I didn't find anything and my moving and pulling on wires as it ran didn't produce any results. As a last resort I picked up a solenoid and swapped it out.
I had also dumped 2 bottles of fuel system treatment into the tank and topped it off with premium gas the week before this.
2 days later it didn't die at all. I've been driving it since then and it hasn't died again. At this point I'm guessing it was either bad gas or the solenoid since those were the last 2 things I did before it improved.
Now I can enjoy it and get back to tuning the carb and getting it running correctly.
