Build Thread 78 CJ5 Farm Find
jpeck71
- Media
- 3
- Chatham, IL
- 1978 CJ5 258 6cyl - 3sp T-150 - Dana20 TC - 2.5 inch spring lift - PO body lift - stock axles - 2bbl Intake and Holley 2300 carb - glasspack muffler - 31x10.5x15
I got this from someone who found it on a farm in Indiana. It was driveable when I got it but had lots of leaks and a really rough idle. Some of the gauges don't work (temp & fuel). Doesn't have an oil pressure gauge. Speedo and odometer works. When he got it the tie rod ends had siezed up and he replaced the ends and tie rod and got the steering working. He also replaced the gas tank and fuel filler neck and put a new sending unit in.
The title as I got it was dated 1997 and in that time the odometer only moved 2000 miles.
It appears to have a relatively rust free frame, but the body has rust and has been bondoed in the past. A PO had removed lots of stuff when it stopped working. There is no emergency/parking brake. All of the EGR system has been removed. It has exhaust headers and a glasspack muffler.
Here's pics of the weekend I got it.
Since then I've replaced the distributor, replaced vacuum lines and have them connected correctly now. I've adjusted the carb as well as I could without a vacuum gauge.
I've started tackling the oil leaks and have taken the oil pan off. I'll leave pics of that for another post.
In the process of starting this I've taken the opportunity to purchase a new set of jack stands and a floor jack. I have a feeling there will be other tool purchases in my future.
I've been learning a lot from my service manual and from reading posts on here. I don't have plans to take the body off, but we'll see what happens. I would like to eventually put a back seat in it but I want to tackle the drivetrain and suspension first.
This is a learning experience and hope to keep it going in the future.
Now I'm looking for a replacement oil pan since I don't want to try and repair this one with welds. I'm not sure that would be worth it or a good idea. O'Reilly Auto here I come!
