78 cj7 quit and won't start
96in85
atlanta
I have spark out of my coil but nothing out of distributor. I removed distributor cap and turned engine over shouldn't rotter button turn?
Yes, the rotor in the distributor should turn as the engine turns. It turns because a gear on the cam turns the distributor shaft. If the cam isn't turning (check valves) then it's the timing chain.
If the vales work then it could be the gear on the bottom of the distributor shaft. Is the distributor OEM? This is a common problem with cheap HEI distributors.
New stroker 4.7 liter with dbl timing chain. Has new ignition module and ditributor and shaft. How do I know if the gear on the shaft is bad?
If you can turn the rotor freely by hand and the rotor is located correctly on the shaft it is a fair bet the shaft or gear on the shaft of the distributer is faulty , , If you turn the engine over by hand by turning the crankshaft pulley and the rotor does not move it is a fair bet it could be the timimg chain broken and not turning cam shaft ,,
DO NOT USE THE STARTER MOTOR TO CRANK THE ENGINE , IF THE CHAIN IS BROKEN A PISTON MAY HIT A VALVE IF THE CAMSHAFT IS IN A POSITION COMPRESSING A VALVE .. THE PISTON WILL LIFT AND HIT THE VALVE AT THE TOP OF THE STROKE
I had the same symptoms. A PO installed an HEI distributor with a brass gear. I sheered that soft metal when I was doing a tune up and adjusting the carb. I think a backfire did it. Now I have a steel (or some metal containing iron) in its place.
-Jon
Bolt backed out of cam gear. It was just spinning.
Guess the 4.7 ain't a zero clearance engine then. Whew......
Push the button. I dare ya!
