79 cj5 304 california complete emmisions equipment needed
shadcj5
Ripon
79 CJ5 304
I just got my hands on a 79 CJ5 AMC 304 and need to smog it in claifornia. Problem is im not sure what equipment I need. I dont believe it has any of the required equipment. Does any one have pick of what I should be looking for? Advice?
A repair manual such as a Haynes, should help. Finding that stuff is another problem. At this time you might want to consider one of the two claifornia smog legal fuel injection kits made by Howell Engine Developments or the Chrysler mpi.
Haynes or Chiltons manuals have a generic diagram and basic overview of the smog system. A FSM is going to be your best bet for detailed info on the smog system.
I absolutely agree with Torxhead about it being simpler and possibly more cost effective to jupst go the EFI route. The OEM smog parts are getting harder and harder to find, and if you do find one they aren't going to be cheap.
Too bad, I tossed my intake and manifolds.. just no need to worry about that stuff in the great state of IOWA.. :D
Might be different for Cali anyways, I'd suppose.. tossed the air pump too... You'd be much happier with EFI..
If you decide to smog it, I have most of the equipment off of mine, 1977 AMC 304 original cali smog junk, let me know, ill get rid of it for cheap.
and if Golden Eagle does not have it
contact J&W auto wreckers, they have so many acres of jeeps it is a crime, are in CA so they will have what you need.
I have a '79 AMC 304 with the SMOG stuff still on it I have been looking for a reason to be rid of it :D(I'm not sure if it is the same as the California stuff though, unles you have a California Jeep I wouldn't think it would matter)
If you decide to smog it, I have most of the equipment off of mine, 1977 304 original cali smog junk, let me know, ill get rid of it for cheap.
Sounds great! What I still need;
Air pump & brackets,
Diverter valve and associated hoses,
Air injection tubes & check valves,
Exhaust manifolds,
cat converter,
delay valves,
Quote your price?
thanks in advance
