Build Thread 79 CJ7 Frame Off Resto 1st Time Project
Peanut Butter
Full Time Jeeper
Boerne, Texas
1979 Jeep CJ7 TH400 Automatic 258 I6 Quadratrac Amc 20 rear & Dana 30 front, 32 x 11.5 x 15 tires. Currently a Complete Custom Rebuild in progress.
Also I own a 2001 Jeep Cherokee, White, all stock with 4.0L. automatic, and police package. Best part of that is it came with leather seats! This package also has the NP242 Transfer Case, 8.25 rear end, and trailer towing package.
Ok, how do I get the bigger pic in? I used the add image on the right below the smilies. Rod
Pulled the engine and transmision off the frame to clean and paint it. It was real nasty but clenaed up nice. Used VHT Paint on the Transmission and Eastwoods ceramic engine paint for everything else. Rod
So after getting all the painting done, I decided to replace the leaking gaskets to prevent another dirty engine. I ordered a complete gasket set from discountjeepparts since it was cheaper that way than ordering just what I needed. Got the valve cover gasket done and moved to the pan gasket. I was vary happy upon engine inspection to find a very clean engine, no slop, andveything looking really good. Then I looked at the timing chain through the bottom of thecover where it is opened to the oil pan. :eek: The chain had a lot of slack in it. When I was driving the Jeep the engine showed no signs of a bad timing chain, so I was surprised. But no big deal. ;) I order one and was glad I found it when I did. Got the cover off and tried to line up the marks on the sprokets........:( There wer two markes on the crankshaft sproket and a pointer and a mark on the cam sproket. You can see some of this in the first picture below. So I rotated the engine till two of the marks lined up and check the mark on the crankshaft balancer to see where it was. It lined up TDC. So I felt good to go. I replaced the entire setup. Notice that the Rugged Ridge sproket for the cam is all metal as compared to the plastic teeth on the old one. Might make more noise, but should last longer. See pictures below. So I set the engine on the frame after replacing all the gaskets I needed to just to see what it looked like. Last picture...lokks good to me. :)
That is a beautiful rolling chasis. You're doing a great job! :notworthy:
Looking good so far, and coming along quick too.
Thanks guys. Got more time than money. Hehehehe :D Rod
That is a beautiful rolling chasis. You're doing a great job! :notworthy: It's the Chrysler thing that I don't understand.
I was afraid of the metal flake blue for AMC. I've never worked with metal flake before, so I decided not to takw a chance and go the next closest color. Rod
Dave and the guys from Storks Automotive are good people. Ive dealt with them many a time. You were almost in my nieghborhood kinda sorta. :)
I just happened to see some parts they had listed on eBay, thought I'd call them and see if they had one. :D Yep, they sure did. $AMC 150 plus about $34 for shipping. I don't think that was too bad given the fact that the junk yards down here have never even heard of a CJ. :mad: Rod
Looking good will keep watching the progress.
$100.00
  50.0%
