Build Thread 79 CJ7 Frame Off Resto 1st Time Project
Rod , love the trailer. If I can't get a Scrambler by Spring I may do the same thing. ThCjs looking good as well. Nice to see your still at it. :chug:
WOW! thats some in depth, and VERY nice workmanship... SO clean and tidy... VERY very nice!
Thanks! I should have a "New Jeep CJ7 " when done. Hehehehe :drool: Rod
The Press is a great addition, I use one at work a lot. :D glad to see you sorting out the front end as well. You'll be happy you did in the long run. I finally found my steering issue was bad axle shaft u joints. Keep it coming. :lpopcorn:
Thanks Pete. :chug: That's actually the same reason I tore into the front axle. My axle u-joints needed to be replaced, so while I had everything tore apart, why not do it all. :rolleyes: That and I got this killer deal on a lift kit. ;) Installing the lift kit also IMHO means that all of the other components need to be up to snuff. Besides, it was fun. :D I've never taken an axle completely apart before. Rod
Looking good Rod. Must be nice to to see it as a rolling chassis now. It was time for those shackles to be replaced for sure. :eek: The things you find when you take things apart.
Congratulations on the new home!
Good to hear your feeling better.
Jeep is coming along nicely, any updates?
x2 getting old is a bitch sounds like you have been thru alot glad you are better always enjoy reading your posts.:chug:
That is one sweet setup! Nice!! Enjoy. I'm still playing hockey 2x a week at 45 and half my team is older than me - keep up the good fight!! Good luck with the neck and back. [emoji106]
Wooly
$100.00
  50.0%
