Build Thread '81 CJ-7 Laredo build
Glad to hear you got it wiped, I have always thought a auto is easier to pull and and install. :chug:
Good work Pete. :chug:
It does help to read the manual every once in a while, even when we think we know what we are doing.:D
I dont know. I like the 4 easy to get at bolts to drop the manual. Then when you go to remove the bellhousing you have more room to get at those bolts. I guess its really just what your used to. Either one can be complicated when you dont remove all the bolts. :D
This is true , but every once in awhile I like to be able to laugh at myself. I just wish it wouldnt happen so frequently. :D Im still kickin myself about those torque converter bolts.:doh:
Had a crappy day at work... trying to motivate myself enough to even go down and clean up the garage. :(
You only have 1 1/2 months left, get out there and get working.:poke:
Got everything bolted up and running today around 5:00. I'll post some of the "highlights" tomorrow. :rolleyes:
It wasnt without any drama as usual for me. Things did go together unusually easy so I shouldve known. There I am having just finished buttoning everything up and adding the Transmission fluid. I get up on my milk crate and dump in quart #1 then slowly quart # 2 everything looks good ,start quart #3 and think I hear dog peeing in garage. I wish that was the case.:rolleyes:
There goes tranny fluid leaking all over the garage floor. (Pan to fat bald guy scrambling for a clean oil pan) then settling for a dirty one to catch the last 3 drops. :mad: After two solid days of working on the Cj this is not the result I was looking for. I look at the back of the pan and see a small curve in the pan and believe its dented. I drop the skid and tear down the pan again. I go outside flip the old Transmission over and am greeted by the same curve in that pan as well. :o
Now Im a little upset but take off that pan as well since I know it didnt leak. Thought I was dead in the water being it was Sunday and I would need a gasket, but removed this rubber one intact. Awesome a bit of good luck. :) I even go as far as to get the torque wrench out and put 13 ft lbs on each bolt like the manual says. I forego putting the skid plate on in case I have to go through this again. Start adding fluid , same dog pee sound, curse up a storm then investigate.
This time around I get there before all the fluid is out cause Im not scrambling for a catch pan. Right above this mysterious curve in the oil pan is a hole in the Transmission to Transfer Case adapter. Not a bad hole mind you , a hole thats missing a bolt. :bang: A previous owner mustve needed a bolt and stole one out of there. Replace with a bolt from the bad Transmission and low and behold no more leak. :rolleyes:
I post my mistakes in the hopes that others can learn from them. More Dumbassery to come. :D
Slow down Pete, take it easy you've got plenty of time yet.
As a side note my power steering pump ate it's self this weekend.
It was a blast getting it out of the woods with no power steering, my arms still hurt.:D
Well I'm glad to hear the leak was a easy fix.
Ha! This was supposed to be a slow overtime month for me with only 2 Saturdays scheduled. Now I find out Im working 7-7 the rest of this week. I have alot of little stuff to get done. Gonna have to squeeze it in somewhere. The Transmission was the biggie though. Glad to have that done.
