Build Thread 81 cj7 rebuild
Quick question regarding the transfer case. I assume the transfer case and transmission can be pulled together as one unit? The transmission looks like it is free at this point, just held on by the transfer case. Shop manual says "disconnect propeller shaft from transfer case" in regard to removing transfer case. My question is what is the easiest way to do that? Should I open up the joint where they are connected? Bolts at that joint have a funny head, like I will need a special tool. Can I disconnect from the transfer case without messing with the joint itself? This is the front propeller shaft, rear is disconnected, it just pulled apart in middle of shaft. Thanks!
Sent from my SM-N920V using Tapatalk
Remove the 4 bolts on the 2 straps that hold the u joint on the yoke, no need to mess with u joint, when done good idea to wrap tape around end of drive shaft so joint doesn't come apart while off the jeep I would think you would have a 6 point or 12 point bolt on your straps
Welcome to the the forum! Glad to see you're jumping in on the build. The guys here will help you out for sure. Keep up the work, keep us posted !
Don't throw that T-5 out with the dishwater. :D
I've run one since I bought my Jeep. :eek::)
What R&P ratio do you have? What tire size will you use?
Might give these folks a call.......
http://www.jwjeep.com/
Be afraid of anydangthing with the Crown name on it. Same for Omix.
:agree: with LG. What do you plan on doing with you Jeep? That should be the first question that everybody answers. That will determine how you attack your rebuild. Mine will be a DD with mild off-road, so I don't need super heavy duty monster mud tires, etc.
Don't throw that T5 out with the dishwater. :D
After I replied I thought about you Lumpy, seems like so many want to trash the T-4 /5 and you have been running one since 1985, I didn't have a problem with my T-4 or T-5 but I didn't run either long enough to comment on their reliability, I ditched em when swapping to an AMC 360
I wouldn't run a T-5 behind any '8'.
That said-I do have a spare T-5 sit'n on the shelf ready, just in case.
It has sat there for 20+ yrs. :D
Thanks everyone, I appreciate hearing from those with real world experience, rather than just reading something on a website. I got this jeep purely for recreation. We have some property about an hour and a half drive from where we live, it is undeveloped, just some trails through it. I would like for it to get me there and back, and otherwise will just be to tool around the property, explore with the kids, etc. Definitely nothing extreme, but will be on and off-trail. The main thing is reliability. I don't want to get out there in the middle of nowhere without cell service and it conk out on me. If I did not have to shell out a grand or more for a new Transmission , that would be great. Previous owner told me that everything seemed solid with the Transmission , but he also told me the engine was running great and that turned out not to be the case. As for some of the other questions, it has 33s on it, don't plan on changing them. Not sure about R&p ratio, how do I find that out and what does it tell me? Thanks for everyone's help!
The 'build tags' might be still on the front or rear axles near the diff cover.
To the right of the rear diff. cover there is a flat area. You may need a wire brush for this. Brush the area and look for a letter stamp.
Thanks PB, but at this point cost is not the major factor. I have more money than time these days, as evidenced by the fact it has taken me so long to get to this point. That's not to say cost is not a factor at all, if it wasn't, I would have just paid someone to do all the work or just bought a jeep that was already done. But since I bought one that needed some work and I am doing a lot of the work myself, I feel like I have some "built in savings". If it would truly be easier and quicker to replace with a new harness, would prefer to go that route.
Looking at some of the other threads, looks like most have had a good experience with the painless harness. The other good option looks like the centech, anyone have any comments on one versus the other?
Sweet I'm glad you are still going after it, looking good
