81 CJ7 starter and flywheel
Gwen
We have been through 4 starters on our CJ7 . It would start fine when we first put the starter in, but on the second crank and any after it would only produce a high-pitch screech...like the bendix wasn't hitting the flywheel. The teeth were ground down some, but there weren't any missing. After the 4th new starter, a new solenoid, new relay and MANY headaches, we found in one of the forums that the flywheel only starts/stops in two places. Upon closer inspection, the teeth were worn more than we thought. We moved the flywheel to where the teeth looked better, replaced the starter and it started right up. So, we've narrowed it down to needing a new flywheel. We are definitely beginner shade tree mechanics. While we know a screwdriver from a pair of pliers, we're not exactly pros at this. Would any of you have a video/pictures/advice that would help us out? We have to get this running soon. Any help is appreciated.
Gwen
Gwen
