Build Thread '83 CJ-7 build
mbcj7
louisiana
1983 cj7 project tailgate
1999 chevy silverado dd/race truck in progress
2010 nissan titan toy hauler
I noticed you don't have the fuel return line hooked up that after market fuel cell. You may wanna check into that. LOL. Here's another idea you may consider for the bricks. Bag 'em, tie a rope to 'em and chunk 'em out when you need to stop. Good luck with the wrenches. P86.
OK I got 2 ?'s. Where did the pix go? Where is home is Looseanna? I'm in Beaumont quite often, might can make a venture by if ya' close enough.
Hmmm I see pix.
I'm in Prairieville. Just outside of Baton Rouge
Well the comet must have left the system today because I can see the pictures. What rhino line did you use? Gimme some details..easy to use..cost..where did you get it..etc.. I'll be posting new to me tub pictures on my thread; so I'm looking at doing some rhino line and rust inhibitor stuff also.
I like hurcliner. can get it at any automotive store or even your local Tractor Supply Co.
I used herculiner. I did NOT take my time and pull the seat belts, or the roll bar. figured I could get it good enough as Ill be replacing a good bit of the sheet metal at a later date. Looking back, it really wouldnt have taken much more effort (assuming I wouldnt have broken any bolts etc) to do it correct.
I picked up the one gallon kit from O'reilly down the road. It's pretty easy. Just skuff the paint wipe down with MEK, Acetone etc and apply
The herculiner sounds good enough for me. I'll do the bottom of my tub in it. The push rod picture is scary. Here's some words to live by "JEEP-just empty every pocket". My manta "Will work for Jeep parts". peace out.
