84 CJ cutting off
With it running I would start under the hood and start moving wires around by hand and see if it dies. I had to replace plug that fits on the coil for that very reason. Good luck and I would love to see some pics also.
Come to think of it, you could also try removing fuses one at a time then doing a spark test or using the multimeter. A wiring schematic could help here. There is a very slight battery drain due to the computer and a clock could provide a slight drain. Good Luck
