Build Thread 84 CJ7 coming full circle
Scooter402
- Back East
- 1984 CJ7 - SBC 402, TH350, Dana 300, Dana 44 front and 12 bolt rear with 4.56 gears, 38" Boggers;
2006 Dodge Ram 2500
Been a little busy here lately. Last week I was doing some work on my truck, and today I've got enough time to post up my progress from the week before. Hopefully tomorrow or the next day I'll have more time to get some more work done. Anyway, on to the progress.
Finished filling in that corner that was bugging me. I ended up slitting the fender, pulling out the sheet metal to butt up against the side of the grille, then snipping out a filler piece and welding it in. Did a little bit more metal filling with the welder, sanded things smooth, and a little more hammering. I put on a coat of primer to see where things sat once I bolted the made-over fender back on.
I'm pretty happy with how this is shaping up. I'll need to skim on a little body filler once I get done with everything just to make it perfectly smooth. Still got a trick up my sleeve to cover those tires for Johnny Law.
Started work on the other fender, too. I removed the inner fender, re-drilled the mounting holes, and slit the mounting flange between the fender and grille in the same fashion that the first one was done. Drilled a mounting hole in the side of the hood, and re-drilled a hole in the flange, then re-installed the fender.
Since I took these pics, I have cut this fender profile similar to that of the first one, sliced off the front of the fender, and am working on re-shaping the pieces to match what I had done on the other. Remember the prediction that repeating the blind beating I was laying down the first time would be painful? Yeah... It's a pain, alright. But at least we're having fun!
