Build Thread 95's 81 CJ5 rebuild
Ok, so to update this, I got the tune up stuff done.
working on the stuff..
New water pump, t-stat, I cleaned up and painted the fan since it had surface rust here and there.
New cap, rotor, plugs, and wires
The old rubber do dads in the valve cover were hard as rocks, so ordered new those too! (also cleaned up the air cleaner)
Then started putting the front end back on..
The motor surrounded by fenders and a grill!
Hey it looks like a Jeep again!
Alright now time to move onto the Transfer Case
Working on cleaning it up
For some odd reason the PO decided the Transmission and Transfer Case didn't need bolted down to the skid.. as a result it slid back and forth, banging into the tub and wearing this bolt down weird and making it almost impossible to remove.
but I got it, and opened it up to peak inside
first gear driven jeep Transfer Case I have owned..
anyway all seemed to look ok, so I threw some gaskets at it and called it good. time to paint it up. the finished product
now time to get this pig back in the jeep.. man was it heavy
but I managed to get it back in by myself
Then threw on the much needed Transmission mount
and cleaned up the skid real quick
threw on some primer
and the final two coats of black
added the new mount deal..
and got her bolted to the jeep again! success!
with the jeeps entire drivetrain back in it, and nothing being held up by jack stands, I decided to roll it out a bit and clean the floor under it..
first time she's seen a little sun in a year or so..
here's a little side project, extra for you guys. I pulled the factory hitch off the 77 and cleaned it up. Worked well I thought.
new grade 8 bolts
I'm pretty happy with how it turned out. I don't plan on towing a whole lot with the Jeep, its mostly for looks. But if anything it will see a little small utility trailer now and then.
One more thing, I found this photo on the internet, I like it. I wouldn't mind my 5 ending up like this. It would make a perfect back country explorer jeep! You know, cowboy hat stuff!
Looking really good :chug: you should be up and running in no time flat. I like the Dinoot trailers they look like a CJ on a harbor freight trailer :chug: that would be pretty neat behind your 5 :chug:
Thanks man, this is the first I have done anything this extensive to a jeep. I have mostly owned 90's on up era jeeps. So this is the oldest I have owned. I'm really hoping the thing doesn't blow up when I go to first turn the key lol
Lol you drove the motor in the garage so your all good, check the brakes before you crank it up
Yeah very true, the brakes are non existent at the moment. The kid that had the jeep before, undid lines here and there. Then left them that way. So that's why I said I want to redo the whole brake system. Stuff is rusty and what not.
Wow I can't believe it's been 6 months since I have updated this. Time to get my butt in gear.
Yep time to get back after it
Time to get that jeep in gear. Summer is just about here!
Welp got some parts ordered and on the way here. Heater core, blower motor, heater core seal, defrost duct, and steering wheel nut. (Mine has been missing since I got it lol)
Gonna probably order a new radiator here soon which should complete the engine and everything. Then it will be working on getting the engine to start and idle. If I can pull that off, I figure it will motivate pretty hard to knock the brakes out.
Sweet
Sweet
Yeah I need to get going on it. It's sat long enough lol
Plus I want to tote it behind my future motorhome. Take it to cool trails you know.
Yes you do summer is coming don't let me get mine done before yours lol
I'm hoping by maybe fall I can have it drivable enough to drive around the backyard, climb some stumps lol
That will be some fun times
Ok got back at it today
Some parts showed up
So I got to work and pulled the heater box
Pulled it apart, got that crappy heater core out of there
New one in
I have to make the firewall bigger to accept the New YJ blower motor. So I need to run and get a thing for my drill. So since I didn't have the tool I installed my new glove box!
That's all for now, I have rear brake shoes and a radiator on the way!
Yay that's awesome Very cool I'm glad to see you are back at it
