A little confused.
A little confused.
My guess is the holes for the line up dowels.
My AMC 304 , which I believe is the same bell housing, has bolts in the positions you highlighted, and pretty sure the last AMC 258 i6 / 4.2l did also. The top center has nothing. If you look at the bell housing, the metal at the 12 o'clock position is quite thin. I don't know for sure, but maybe this hole is for mounting a bracket for something on an automatic Transmission . Definitely not a factor in holding the bell to the engine.
Every one that I've ever seen only has a bolt and nut pinching the bellhousing and plate together. I never could figure out why. But then I'm no engineer.
I can't even see the pocket that the pilot bearing goes in at. Almost like there is a broken shaft of some sort in there!
Edit: Compared to other pics of the Ford style T-18 on the net, the pilot shaft looks a bit larger.
