A tale of two carbureutors
Helomedic1171
- Savannah
- '85 CJ7 258, T-176, D300
'58 CJ5 F4-134, T-90, Spicer 18
'54 M38A1 F4-134, T-90, D18 (28VDC and milspec parts)
So, while I'm finishing up a combination oil pan gasket, oil pump/pick-up, and battery cable replacement, I decided to go tromp through the junkyard. I hate the way the Carter BBD (I assume that's what I have) makes the AMC 258 i6 / 4.2l in our CJ7 idle and run. I couldn't believe my luck when I found what I'm fairly certain is a MC2100 or 2150 sitting, untouched, in a 1984 E-AMC 150 . I snatched it up, and since I have an older 2100 at the house I can use for parts, I giggled all the way to the local O'Reilly auto parts.
Here's the deal. I have a rebuild kit, I have both carbs, but which one is more desirable for use on my 85 CJ7 ? I plan to do the junkyard MPFI conversion sometime in the next year, but for now, I want it to run better til I get to that point. the carb on the left in the photos is the one I just found, the one on the right is a well-worn unit I got from a dude in Canada. they each have different features, but which one is the better idea for my CJ7 ?
I live in coastal Ga, so a choke is not necessary, and I can run a manual one if I need to or mess with the electric choke if need be.
here's the I.D. tag from the newer one I just found:
let me know what you think, I only know what the internet says about these things, and I've only scratched the surface, I think.
