Adding a transmission cooler
gr8dain
Full Time Jeeper
Soon I will be swapping my T-176 four speed for a TF999 auto. I plan on adding a Transmission cooler.
For those of you running an auto with a tranny cooler, what set up are you using? Cooler in front of the radiator (I have a champion aftermarket radiator)? Do you have the cooler running in series with the radiator or just directly lined to the tranny?
If not in series with the radiator, do you have a temp sensor and gauge? How do you add fluid to the system?
Thanks. Trying to get all of my homework done before starting.
